Squealing and "Flapping" noise
169,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
BRUMMET
  • 14 POSTS
Hello! I was driving to work earlier this evening and my car made a new noise. There was a squealing coming from under the hood, which has been relatively normal when it is cold out. Today, however, I noticed it was worse than usual. I figured I had a belt that was going bad. However, when I was almost at work (I have a 30–40-minute commute) the squealing stopped and now it can be described as only a flapping noise. That is not the best description, but it is all I got because I have never heard this noise coming from my car. It almost sounds like a really old beater when it revs, but you would have to hear it to understand what I mean most likely. Anyways, I have another 40-minute commute home in the morning, and I am really concerned about how safe it is going to be to drive this car home. It isn't any of the belts that I could physically get to under the hood, and it should not be the timing belt because A) it still drove the last mile without an issue and B) I just had the timing belt replaced not even a year ago along with the entire water pump assembly. Any ideas? Thank you ahead of time.
Feb 3, 2022 at 11:17 AM
SQM
  • 6,383 POSTS
You might want to open the hood and inspect the serpentine belt. It is possible that it is shredded and the flapling noise the belt hitting something.
It will be a good idea to inspect under the hood, especially the belt, as well as look for anything unusual or out of place. Check the oil to make sure it is not low and creating noise.
If the belt is damaged you do not want to drive without fixing it first, to prevent damage.
Please let me know what you find or if you have any questions.
https://www.2carpros.com/articles/how-a-serpentine-belt-works
Feb 3, 2022 at 12:02 PM
BRUMMET
  • 14 POSTS
Hello, thank you so much for responding so quickly! I did check under the hood, and it seemed like the 2 (?) belts I could see were fine. They felt like there was tension when I gave them a little tug because that was my assumption first as well. I could go check the oil when I get a minute at work but I just got an oil change at the end of December so I do not think it is that as well, but I will check.
Feb 3, 2022 at 12:05 PM
SQM
  • 6,383 POSTS
Sure, no problem.
See if you can hear the noise with the engine running and the hood open.
Also if possible upload video so we can hear the noise, possibly with the hood open as well.
Feb 3, 2022 at 12:15 PM
BRUMMET
  • 14 POSTS
I will do that as soon as I get a second at work!
Feb 3, 2022 at 12:26 PM
SQM
  • 6,383 POSTS
Sounds good. I will look out for it.
Feb 3, 2022 at 12:28 PM
BRUMMET
  • 14 POSTS
Well, I think I found the problem! The question now is: can I get home? I’m 20 something miles away in another city for work, and my wife works in the morning so she can’t come get me. I can drive her car to work this weekend and I can get it dropped off Monday morning but I’m kind of out of luck until then as far as getting it home.
Feb 3, 2022 at 12:51 PM
BRUMMET
  • 14 POSTS
Sorry, I don't know why the video did not upload the first time. Uploading now...
Feb 3, 2022 at 12:52 PM
BRUMMET
  • 14 POSTS
While I wait for that, I can describe it to you. One of the accessory belts is vibrating back and forth while it runs, that's what is making the sound.
Feb 3, 2022 at 12:54 PM
SQM
  • 6,383 POSTS
I haven't seen the video yet. But if the belt is vibration back and forth it could be due to a loose pulley. Any time you have issues with the belt, it is best not to drive unless you are able to fix the issue. Because the belt can come at any moment on the road and get you stranded and can-do other damage.
See if you can tell which pulley might be loose.
Feb 3, 2022 at 12:57 PM
BRUMMET
  • 14 POSTS
Here, maybe?
Feb 3, 2022 at 2:41 PM
SQM
  • 6,383 POSTS
Got the video. It is surprising that the belt did not break off.
I would not recommend driving the vehicle in this condition. The last thing you want is to have a broken belt and get stranded somewhere in the cold and bad weather.
Are you able to tell if the belt has proper tension or which pulley that might be loose?
Feb 3, 2022 at 2:49 PM
BRUMMET
  • 14 POSTS
I cannot based on my extremely brief look. I can have it towed in the morning, I guess.
Feb 3, 2022 at 3:09 PM
SQM
  • 6,383 POSTS
It is always to keep in mind of safety first. Let me know how it goes.
Feb 3, 2022 at 3:22 PM
BRUMMET
  • 14 POSTS
Is this something that could be remedied relatively easily? If it is a loose pulley, can I just get in there with some hand tools and tighten it or is this something that requires some expertise and advanced equipment?
Feb 3, 2022 at 3:26 PM
BRUMMET
  • 14 POSTS
Like, if it is as easy as just tightening the belt, I can probably do that pretty easily if I had my socket set with me. Then I could avoid a $150.00 tow charge.
Feb 3, 2022 at 3:31 PM
SQM
  • 6,383 POSTS
It is likely little more than just tightening the belt.
By the way, does the belt appear to be too loose, with the engine off.
Looking at the diagram, I think that belt that is making the noise is for the A/C. So, it primarily runs the A/C.
It should go around the A/C compressor and the crankshaft and an idler pulley.
So, if you can remove that belt, you will be able to drive the vehicle without worrying about it braking as you are driving. Also, since this is the A/C belt, it will not affect anything besides that it will not turn the compressor (which will be no A/C, but that should not be an issue with this weather).
The issue is that belt can only be removed if the other larger belt gets removed first. Which you cannot do without tools.
Feb 3, 2022 at 3:39 PM
BRUMMET
  • 14 POSTS
I see, what kind of tools are we talking about? I can get a socket set, if need be, and I found a tutorial for changing a 2004 Forester's belts that I will link below. If it is the A/C belt, I can remove it and then order a new one and replace it myself. But as far as getting home, if a socket set is all that is standing in my way, then that is more than doable.
Feb 3, 2022 at 3:42 PM
SQM
  • 6,383 POSTS
That instruction is the same one for your vehicle.
So yes, if you can remove the belt then it can be driven without worrying about the belt snapping off and causing issues. Especially the broken belt can get tied up on the other belt and damage it or break it.
Feb 3, 2022 at 3:44 PM
BRUMMET
  • 14 POSTS
You, my man, are an absolute gem. I am going to try and get a hold of maintenance and get myself a socket set so I can hopefully get home. I will keep you updated! Again, I cannot thank you enough.
Feb 3, 2022 at 3:45 PM
SQM
  • 6,383 POSTS
You are welcome. I do hope you are able to get this done.
Feb 3, 2022 at 3:47 PM
BRUMMET
  • 14 POSTS
I do have one more question. So, I have thought about what I am going to do having limited resources and such at work. Theoretically, if I am going to replace the belt anyways, I have debated just cutting it. My question is though, is there anything that the idler pulley does that will be affected by removing the belt? That is my only remaining concern as the final pulley will still be engaged by the remaining belt. If I get to it before you see this, I will let you know how it goes. LOL
Feb 3, 2022 at 6:55 PM
SQM
  • 6,383 POSTS
In this particular case you can cut the belt, since there is not a spring loaded tensioner, it should be just fine. The idler pulley is there just to properly guide the belt.
Feb 3, 2022 at 10:04 PM
BRUMMET
  • 14 POSTS
So, I did this, and it worked. The belt was okay, actually, but it’s a cheap belt I’m not too worried about. The bigger issue is the idler pulley. It’s in pretty bad shape. Looks like whoever did the belts last tightened it a little too much because it’s super worn down and almost melted looking. I will be looking to repair that sometime, though I may wait till it gets warmer out, lol.
Feb 4, 2022 at 2:10 AM
SQM
  • 6,383 POSTS
I am glad it worked for now. It's a good thing that it is not summertime, depending on your location, that could be difficult with no A/C.
Let me know if you come across anything or have any questions.
Feb 4, 2022 at 2:21 AM
