Squealing
180,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
LAURA RAYNE MONK
The cv joints went out, replaced them, replaced brakes, brake pads and master cylinder, replace the belt, the tension pulley and the idle pulley. There are no loose hoses for a vacuum to be squealing, but there is a high pitched squeal when accelerated. I have no idea what it is and why its happening.
Jun 21, 2016 at 2:16 PM
  • 31,937 POSTS
If it sounds like belt squeal, the serpentine belt may be the wrong one and a bit to long, re check the size, it may feel tight on the tensioner but if it is just a little over size it will make a noise.
Jun 22, 2016 at 7:30 AM
