squeal or whining during acceleration
170,000 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
STEVENRACHEL
  • 5 POSTS
when i accelerate i have a squeal or whining that gets louder the harder i push the gas pedal. when i back off the accelerator the sound goes away. i am also having problems with my transmission shifting from first to second and to drive. i replaced my tension pulleys and drive belts already.
Jun 30, 2017 at 9:32 AM
  • 55,564 POSTS
We need to see if the problem is belt related, can you remove the belt and then start the engine and rev it to see if the noise is gone please?
Please run this test and get back to us we are interested to see what it is.
Cheers, Ken
Jul 3, 2017 at 4:43 AM
STEVENRACHEL
  • 5 POSTS
I took all the belts off and it still squeals. It sounds like it's coming from the intake or the transmission. I'm having a hard time gaining rpms and getting over 45 mph
Jul 8, 2017 at 11:56 AM
  • 55,564 POSTS
Yep, it sounds like the transmission is having a problem. I would try a service first here is a guide that can help you with that.
Cheers, Ken
Jul 8, 2017 at 1:19 PM
STEVENRACHEL
  • 5 POSTS
I have been looking for information on how to change the transmission filter on the 2005 Kia Sedona and all I can find is it's not serviceable. The filter is internal? Is this true and do I have to remove the transmission to change that ?
I can't find any information on it.
Jul 10, 2017 at 12:41 AM
  • 55,564 POSTS
Yes some cars you can just drain the fluid becasue the filter is internal and can only be changed by removing the transmission.
Jul 10, 2017 at 3:03 AM
STEVENRACHEL
  • 5 POSTS
Is the 2005 Kia Sedona one of the vehicles that the transmission has to be removed to change the filter?
Also is there a link that I can go to to see how to change the filter on the 2005 Kia Sedona.
Thank you for all your help I really appreciate it.
Jul 11, 2017 at 1:22 AM
  • 55,564 POSTS
After double checking the filter problem I have found they don't have a filter which could mean an internal O ring seal has let go. This mean the transmission will need to be replaced. Sorry.
Cheers, Ken
Jul 11, 2017 at 9:15 AM
STEVENRACHEL
  • 5 POSTS
thank you for all your help and information
you were extremely helpful when i couldnt
find the right information. you helped me
stop banging my head against the wall
guessing and grasping at straws. i will
recomend this sight to everyone i can who
needs help. you are awesome!!!!!!!!
Jul 11, 2017 at 11:25 AM
  • 55,564 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Jul 11, 2017 at 12:08 PM
