2005 Kia Sedona Changed breaks now car is squealing when ac
2005 KIA SEDONA
64,000 MILES • 6 CYL • FWD • AUTOMATIC
A10560
Yesterday we changed the front brakes and the rotors on our van. Now suddenly there is a squealing when I hit the gas. If I hit the brakes the noise stops. Also if I slightly turn the wheel when it is making the noise it stops. Any idea why as soon as we change the brakes this noise would start.
Dec 20, 2009 at 3:18 AM
MATHIASO
  • 1,209 POSTS
https://images.2carpros.com/forum/automotive_pictures/46384_brake_component_1.jpg
Hello A10560 Welcome to 2carpros. What you will need to do is to recheck the job done. Recheck the whole installation of the brake. There may be a loose inner shim, or brake pad retainer. Tighten caliper-mounting bolts to 18-26 ft. lbs. (24-35 Nm). Loose inner shim is most like .
Dec 20, 2009 at 4:35 AM
