squeaking sound on right in serpent belt area
122,000 MILES • 1.2L • 4 CYL • 4WD • AUTOMATIC
SHARONLB
When I start it up , it makes a pretty loud squeaking sound around the serpent belt area. It gets quieter after it runs a bit. I sprayed some WD40 on the serpent belt and it stops right away. However, after it sits it will make the noise again when I start up.
Mar 4, 2018 at 4:43 AM
Good afternoon.
If the noise went away, the metal ribs are showing on the belt. I would replace the belt and the tension-er together.
Mar 4, 2018 at 5:01 AM
WRENCHTECH
  • 20,758 POSTS
Just change the belt. It is dried out.
