Squeaking sound when driving
100,000 MILES
LOU20
  • 88 POSTS
I change my timing belt, A/C belt, and alternator belt. My car still has a loud squeaking sound when driving.
Nov 25, 2019 at 4:31 AM
  • 110,246 POSTS
Is the sound only heard when driving (moving) or could you be parked with it running and still hear the noise? Also, is there anything you can think of that makes it worse or go away?
If it is possible, please record the sound and upload it for me to hear. I can usually identify things easily that way.
Nov 25, 2019 at 12:57 PM
LOU20
  • 88 POSTS
I only hear the sound when driving. If I drive at a low speed you can hear it good.
Nov 25, 2019 at 8:49 PM
  • 110,246 POSTS
Are you sure it is related to the belt? If you only hear it when driving, I would first suspect something with the brakes or wheel bearing. Does the sound chance when the brakes are applied or when you are making turns?
Nov 26, 2019 at 8:51 AM
LOU20
  • 88 POSTS
I'm not sure it's coming from the belts. But I hear it when I'm driving not sure if it's a bearing.
Nov 26, 2019 at 10:01 AM
  • 110,246 POSTS
Is it loud enough to record? Also, if you place the vehicle in neutral and slightly rev the engine (car not moving) do you hear it? If the belt is still making noise, you should. Let me know. Also, you could even have a bad bearing on one of the belt driven pulleys.
Nov 26, 2019 at 10:10 AM
LOU20
  • 88 POSTS
It's not loud enough to record I only hear it when driving. I hear the noise on the driver side.
Nov 29, 2019 at 11:56 PM
  • 110,246 POSTS
Does it change when you apply the brakes or make turns?
Nov 30, 2019 at 1:50 PM
LOU20
  • 88 POSTS
When I apply brakes the noise goes away.
Nov 30, 2019 at 7:41 PM
  • 110,246 POSTS
Then the noise is brake related. Check the brake pads to make sure they are good and the warning sensor isn't touching. Also, there us a backing plate behind the brake rotor that can rust, get dirt behind it, or even get bent. Make sure it isn't touching.
Let me know what you find. I can help more once we determine the cause. However, based on your description, I am 99% confident it is something with the brakes or brake assembly.
I attached two pics below. You need to remove the tire to check the brakes. In the first picture, I highlighted the area that you look through to see the pad thickness. In the second, I highlighted where the backing plate is located. What I would suggest is to turn the rotor when the wheel is off to see if you hear a rubbing sound. Also, if you look at pic 3, it shows the difference between a new and old pad. The item I circled is the sensor that is made to rub the rotor when the brakes wear out. It touches the rotor and makes a squealing noise to warn that the pads need replaced and to prevent you from damaging the brake rotors.
I will watch for your reply
Dec 1, 2019 at 9:49 AM
LOU20
  • 88 POSTS
Is it possible it could be the egine, transmission or power steering causing this noise?
Dec 18, 2019 at 8:13 AM
  • 110,246 POSTS
Anything is possible, but since the sound stops when you apply the brakes, in most every case, it is brake related. Have you checked to make sure the pad sensors aren't touching? Also, have you checked to make sure the backing plate behind the rotor isn't bent or rusted and touching the rotor?
I wish I could hear the sound. It would make things much easier for me. Has it gotten worse to a point you could record it? Also, I know it stops when you apply the brakes. Does it change when you make turns?
Dec 18, 2019 at 10:38 AM
LOU20
  • 88 POSTS
Is it possible it could be the engine, transmission or power steering causing this noise?
Dec 18, 2019 at 11:27 AM
LOU20
  • 88 POSTS
The video is a sample of the same noise my car is making.
Dec 18, 2019 at 11:28 AM
  • 110,246 POSTS
I feel really bad, but I can't hear any difference from driving and braking. Have you tried lifting one wheel at a time to see if there is a noise if you turn it by hand?
Dec 18, 2019 at 11:52 AM
LOU20
  • 88 POSTS
No yes it's hard for me to catch the noise. I'm check my brakes, rotors, and belts.
Dec 18, 2019 at 9:37 PM
  • 110,246 POSTS
Sounds like a plan. Let me know what you find.
Dec 19, 2019 at 11:02 AM
