Squeaking noise when I brake hard
2014 KIA
45,000 MILES • V12 • AUTOMATIC
JAUAN SMITH
The vehicle is relatively new. I got it a month ago from a dealership, where they sent it through maintenance and gave the thumbs up and it has about 45,000 miles on it. When I press the brakes lightly I do not hear anything but when I apply more pressure that is when I hear the squeaking. I am not sure what it could be other than glaze or wear and tear but wear and tear does not really make sense to me because like I said they went through and checked everything before they sent me away with the car.
Apr 28, 2017 at 7:48 AM
HMAC300
  • 48,601 POSTS
if you hear squeaking just while driving it may be an indicator that the brake pads are worn . You could also have one of the dust shields rubbing against rotor or a shield rubbing against something under the car so check those out.
Apr 28, 2017 at 8:22 AM
JAUAN SMITH
Do you know how much any of those options could cost to fix?
Apr 30, 2017 at 6:27 AM
HMAC300
  • 48,601 POSTS
no, prices vary by location as well as where you go. dealers are more expensive normally.
Apr 30, 2017 at 6:31 AM
