2006 F-150 5.4 4x4, about 190,000 km. The first grinding noise went away when I reconnected a passenger-side vacuum line that was completely off. After that I had a separate thud I could feel through the floor around 40–50 km/h. That stopped and I drove normally for a few days. Then I parked, shut it off, fired it back up and got this new grinding near the driver’s front wheel even at walking speed. The video is of the current noise. One shop said front diff. What would you physically check first to tell whether it’s the vacuum hub, brake, wheel bearing or the diff?
Nov 26, 2026 at 3:16 PM
