Squeaking/chirping from front left wheel
2001 CHEVROLET SUBURBAN
175,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JASONCYATES
  • 5 POSTS
It makes the noise when accelerating, coasting or braking. The pitch changes sometimes when braking, but not always. I've removed the wheel, caliper and pads - and they are at least 80%. The brake pad indicator is not rubbing the rotor. The sound is high pitched and is not a grinding sound. I replaced the rotors with the pads in February. The sound comes in a steady rhythm - so there is a spot on the hub / axle / rotor/ wheel that is rubbing something once per rotation I presume. When turning the axle with the tire off, it turns smoothly when holding the rotor / brake pads tightly in place.
Maybe related / maybe not - sometimes when turning sharply at low speeds, the car will 'slip' as if something int he steering mechanism slipped. The front end shifts slightly. There is no sound associated with that.
Lastly - I checked the tightness of the lug nuts when re-installing the wheel. They are all very tight (star pattern when tightening) except even though tight, there is one lug that seems to appear 'shorter' by maybe 2 threads - maybe 1/8" max than the others. The nut is as tight on that lug as it can be, but the end of the lug doesn't poke through the nut as far as the others - as I mentioned maybe 1/8" difference at most. Almost seems to be optical illusion it's so slight. But maybe enough to make a difference?
That's all I know. Can you help?
Thanks!
May 9, 2015 at 5:01 PM
CADIEMAN
  • 3,544 POSTS
This happens when the bearing hub goes out and needs to be replaced. here is a guide and video to help you get the job done:
https://www.2carpros.com/articles/bearing-hub-replacement
and
https://youtu.be/ZgiPRG6jffc
Here is the part on Amazon for $72.00:
https://www.amazon.com/gp/product/B078Z2CR32/ref=as_li_qf_asin_il_tl?ie=UTF8&tag=2carprcom-20&creative=9325&linkCode=as2&creativeASIN=B078Z2CR32&linkId=375b023ab0d9114a47a92bc7f54a305a
Please let us know what you find.
Cheers
May 9, 2015 at 8:13 PM
JASONCYATES
  • 5 POSTS
So good I took off the bearing hub, it apart and it fell apart in my hands you. were so right All fixed now cheaper than I thought. I love this site. I did both sides just to be safe.
May 10, 2015 at 2:57 AM
CADIEMAN
  • 3,544 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers
May 10, 2015 at 9:07 AM
