Grinding noise
243,000 MILES • 5.3L • V8 • 2WD
MARTINCS
I heard a grinding noise at left front wheel. Replaced rotor and pads on both from wheels. test drove it and still makes the same noise on the same wheel.
Feb 2, 2017 at 1:17 AM
HMAC300
  • 48,601 POSTS
check the wheel bearing drive in a right hand circle see if noise increases. also, check for a bent shield touching rotor and or rust.
Feb 2, 2017 at 1:34 AM
MARTINCS
It only makes it when braking and louder at the end of a stop. Would that still be related to bearings? I lifted the car I could hear the bearing sound when turning the wheel by hand.
Feb 2, 2017 at 4:42 AM
  • 55,770 POSTS
Hey Martincs,
Yes this sounds like a bearing issue, here is a guide that will show you how to replace it, you can get a replacement from Amazon.
https://www.2carpros.com/articles/bearing-hub-replacement
Please let us know what happens so it will help others
Best, Ken
Feb 5, 2017 at 6:22 PM
