Squeak when backing up
166,000 MILES • 4 CYL • 2WD • AUTOMATIC
JTOPPING
When I back out of the driveway in the morning (or when not driven for a while) the car squeaks. Sounds like brakes. In my Volvo it was emergency brake, and had to have it replaced. Is that the case with this car?
Jul 30, 2018 at 1:28 AM
  • 55,677 POSTS
This is normal you are hearing hearing the surface rust being removed as you hit the brakes I am assuming the brake pads are in good shape? If you need brakes these guides can help.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
and
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
Cheers, Ken
Jul 31, 2018 at 6:21 AM
JTOPPING
Thanks.
Jul 31, 2018 at 10:14 AM
