Sputtering only while driving
215,670 MILES • 5.7L • V8 • 4WD
MICHALE FASTHORSE
I was driving down the highway then my SUV started to lose power and sputter but idled just fine in park.
May 1, 2020 at 11:32 PM
Good morning,
It sounds like you have a misfire under load.
How long since you replaced the plugs? It could be a spark plug breaking sown under a load.
Is the check engine light on? If it is, do you know the code? You can have the codes read for free at a parts store.
May 2, 2020 at 12:38 AM
MICHALE FASTHORSE
I changed the spark plug wires and spark plugs last August and no check engine light.
May 2, 2020 at 7:43 AM
Okay that was last August and this is now. Any one of the plugs could be breaking down under a load. I would not assume anything at this point.
I would also check the fuel pressure as well.
May 2, 2020 at 8:01 AM
