I have a Z71 TBI. I let it run for about forty five minutes to charge the battery before a big snow storm. After forty five minutes I tried to drive the truck away and it stalled out. It took a few times before it turned over again and once it was running any time I pushed on the gas pedal more than just slightly the engine would cut out and almost stall. The next day it seemed to run just fine. A few days later it started to do act the same and when I gave it more gas it would backfire. I checked the distributor cap and the injectors and they seem fine. After I put everything back together it ran perfect, but four hours later when I tried to drive it it would cut out or bog down when I pushed on the gas but never backfired again. I have been told it is a head gasket or timing or bad plugs. I do not know where to start or what to do. This is my dream truck and I do not want to take it to a auto shop if it is something I can fix.
Feb 3, 2017 at 4:52 AM
