sputtering
65,000 MILES
PLEASEHELP8706
My van runs fine at first but after a while it starts to sputter. It dies and I pull over and try to start it. It starts fine. Once you put it in drive it either dies eight away or once u push the gas it dies. If you push the gas to the floor it will go but sputters a lot. If you let the van sit for a while it runs perfectly fine
Apr 30, 2013 at 8:46 AM
we have no engine size to work with.
i would start with a fuel pressure test
Apr 30, 2013 at 7:37 PM
PLEASEHELP8706
Ok is that something I can do? Or do you have to go to someone? It is a v6
May 1, 2013 at 5:34 AM
