Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
T100
Suspension
Leaf Spring
Perch
Spring perchs
1997 TOYOTA T100
100,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
WERT43
MEMBER
Do I really need spring perches?
Mar 21, 2018 at 3:31 AM
Experienced Mechanic
Good afternoon.
Why do you ask? Has someone said you needed them to be replaced?
The simple answer is yes, you need them.
Mar 21, 2018 at 6:35 AM
WERT43
MEMBER
Have to change rear end. One I bought goes under leaf but, one I removed goes on top. Having a problem cutting them off. Side grinder burned up.
Mar 21, 2018 at 7:21 AM
Okay, you may have the wrong rear end. You may have the one for the heavier duty model.
Where did you get the replacement?
Mar 21, 2018 at 7:25 AM
WERT43
MEMBER
Junk yard everything matches up except perches!
Mar 21, 2018 at 8:06 AM
the replacement needs to be placed in the same spot you removed the old one. if it does not mount correctly, then you have the wrong differential.
Mar 21, 2018 at 8:13 AM
WERT43
MEMBER
I have measured everything all the same except the way it mounts to springs.
Mar 21, 2018 at 8:16 AM
that is what the difference is. that is why it is wrong.
if you mount it under the springs the truck will be very high in height, that is if you can correctly mount it and center it.
Mar 21, 2018 at 8:28 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
