Truck will only start when I remove cylinder 2 and 3 spark plugs. How do I fix this?
Sep 1, 2025 at 4:15 AM
MECHTRIX
✓Experienced Mechanic
Sounds like the classic blown head gasket. check the compression in those 2 cylinders to see they could be leaking between them.
Sep 1, 2025 at 1:16 PM
MECHTRIX
Did it over heat before this ? Any codes or check engine light on the dash ?
Sep 1, 2025 at 1:17 PM
JOHN ENGEL
MEMBER
No. I did compression check. number 3 is at 130 PSI all others are 185 psi. Would this indicate head gasket?
Sep 4, 2025 at 1:43 AM
MECHTRIX
Probably not blown but not sure yet take the cap off and check the radiator see if theres any milky Sludge in the filler neck
Also check the oil for the same Sludge on the stick if theyre clean let me know also it would be great if you could post a photo here ..let me know thanks good luck
Sep 4, 2025 at 8:53 AM
MECHTRIX
There are a few things that can cause this problem we can work to rule them out ..is it possible someone crossed the coil plugs on numbers 2 and 3 ?
Sep 4, 2025 at 8:56 AM
MECHTRIX
Also when is the last time it was running well ?
Was any work performed since then ?
Sep 4, 2025 at 8:57 AM
MECHTRIX
You truck came with 2 different coil types
1..coil on plug type (each plug gets its own coil )
And
2..coil pack ( a block wich all 6 wires plug into )
Wich type does yours have ? Description 1 or 2.. ?
