No problem. If you look below, I included the directions for the removal and installation of the transmission and slave cylinder.
All of the directions below are the removal/installation directions. The last two are for the removal/installation of the slave cylinder.
Let me know if this helps. Also, if you do decide to do this, it's the perfect time to replace the clutch, pressure plate, and release bearing. I'm here if you need anything.
Images (Click to enlarge)
Jun 8, 2022 at 1:30 PM
