Spongy brake pedal when engine running
2002 CHEVROLET BLAZER
160,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
JOHN WIELAND
Spongy pedal goes to floor! I have replace the master cylinder two times with new ones, the booster, rear calipers, ABS module, have bleed a gallon and a half of dot 3 fluid through it. I have had it to one shop two times and to the dealership and they both did the scan tool bleed for the ABS pump. have gravity bled ten minutes a wheel pure fluid. I have good pedal until I start the engine. please is there any help out there?
Apr 11, 2018 at 9:30 PM
HARRY P
  • 2,292 POSTS
Exactly what do you mean by spongy? Does the pedal go to the floor, or just travel further than most other cars. Because the brakes in most Chevrolet trucks are like that. However, it could just be that you need to change the brake fluid. Over the years, with the heating and cooling of the brakes, the fluid can become more compressible. Thus the feeling of sponginess. I would suspect there is air in the lines. These guides can help you fix it.
https://youtu.be/w7gUsj2us0U
and
https://youtu.be/WDxvEQrMkBg
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Mar 19, 2021 at 4:54 AM
JOHN WIELAND
yes the pedal goes to the floor or it feels like a master cylinder bypass you hold the pedal it goes to the floor! after a gallon and a half of fluid bled through it would think it is flushed good clean new fluid coming out on all four wheels.
Mar 19, 2021 at 4:55 AM
HARRY P
  • 2,292 POSTS
Well then I am as stumped as you are. I will say that just standing on it, my 2002 Blazer will go to the floor, eventually. But it stops on a dime when driving, even when suddenly braking hard.
  • 55,433 POSTS
Here is what we do, take sets of vise grips and use cardboard to cushion the grip jaws against the rubber brake line and gently close them off. This will help us decide if it is master or wheel related, should have hard pedal. Let us know.
Cheers, Ken
