Brakes
150,000 MILES • 4WD • AUTOMATIC
WOOLWINE4
I backed my blazer up onto ramps to work and the rear end and while it was up before doing any work I pushed the brake pedal to move it up a little more and the pedal went to the floor what could cause this? Im affraid to lower it from the ramps due to its in front of my garage and I dont wanna drive through my garage door thanks in advance
Aug 25, 2016 at 1:49 AM
HMAC300
  • 48,601 POSTS
well you can open the door first before you take it off the ramps. check master cylinder to see if any fluid is in it. if it's really low then the system will have to be bled to get air out which can be a problem sometimes.
Aug 25, 2016 at 5:03 AM
