When driving sometimes many lights come on. If stopped still running and parked running ten minutes working good, one or two or there times a day.
Nov 3, 2018 at 10:57 AM
✓Experienced Mechanic
Good evening.
There are many lights that can come on.
There is check engine light, ABS light, charging light among a few.
Can you post or upload a picture of the lights you see?
Nov 3, 2018 at 12:07 PM
TIANJINJOHN
MEMBER
Thank you for my question. I asked my brother he told me maybe ECU has some damage.
Image (Click to enlarge)
Nov 3, 2018 at 12:14 PM
Got it.
You have the ABS, vehicle stability control and red brake light. That indicates a fault in the ABS system. There is a code stored and you need to have the code read to help determine the cause of the failure.
You can get a parts store read it for free. Once you know the codes then I can help you pinpoint the failure.
The other light is a low pressure indicator for your tires. Make sure all your tires are pumped to the proper spec on the side of the tire.
