Splash shield installation
130,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
WILLIS1PIE
I was replacing the water pump and timed the car, but when I was putting everything back together I forgot how the inner splash shield goes back on. does anyone know. On the car listed above RT model.
Jan 21, 2019 at 1:59 AM
Good afternoon,
Do you mean the one behind the right front wheel that covers the lower pulley?
It should be a two bolt shield.
Can you post a picture for me to see?
Jan 21, 2019 at 2:18 AM
WILLIS1PIE
Here is the picture.
Jan 21, 2019 at 2:25 AM
  • 55,710 POSTS
it bolts to the inner frame rail on the passenger's side see the bolts holes along the upper edge this is where it attaches. Can you take a picture of the frame rail so I can confirm?
Jan 24, 2019 at 5:28 AM
