Spiral cable on steering wheel
80,000 MILES • AUTOMATIC
MEGHDEEP DHUNNOO
  • 6 POSTS
Hello.. Am having some issues on my steering. It's as if there is something oscillating whenever when I turn my steering. As if a marble is oscillating from left to right.. Is it a spiral cable problem? Please advice.
Nov 10, 2019 at 11:12 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds like you may be having a problem with the air bag clock spring. It is located in the steering column mounted underneath the steering wheel. Here are tutorials showing your possible symptoms and how to replace:
https://www.2carpros.com/articles/symptoms-of-a-bad-airbag-clock-spring
https://www.2carpros.com/articles/steering-wheel-clock-spring-removal
Hope this helps and thanks for using 2CarPros.
Nov 11, 2019 at 6:52 AM
MEGHDEEP DHUNNOO
  • 6 POSTS
Thank you Mr Danny for your guide and advice.
Nov 17, 2019 at 11:17 PM
  • 55,616 POSTS
Here are the instructions on how to replace the clock or spiral spring for you to see in the diagrams below. Can you please shoot a quick video with your phone so we can hear the noise? that would be great. You can upload it here with your response. Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
Nov 19, 2019 at 1:50 AM
MEGHDEEP DHUNNOO
  • 6 POSTS
Hello Mr Ken.
The noise is as if a marble or a piece of rock is stuck inside the steering badge cover and it is oscillating from here and there. Will try to send you a video as soon as possible.
Nov 19, 2019 at 2:22 PM
  • 55,616 POSTS
Please do are interested to see what it is.
Nov 20, 2019 at 2:13 AM
MEGHDEEP DHUNNOO
  • 6 POSTS
At nearly 1 minute of video.
Nov 20, 2019 at 6:14 PM
MEGHDEEP DHUNNOO
  • 6 POSTS
Another video.
Nov 20, 2019 at 6:37 PM
  • 55,616 POSTS
Thanks for the video. it does not sounds like the clock spring. can you jack the front of the car up off the ground and try the video again please? Here is a video to help you:
https://youtu.be/xLFn_bMkZc0
Nov 21, 2019 at 4:46 AM
