Spins over and try to crank but does not
2000 SATURN SEDAN
231,148 MILES • 1.9L • 4 CYL • 2WD • MANUAL
JRODTEDDER
I'm turning the car in to a race car i got the car from a scrap yard. it didn't have a key so I got a steering column out of or that has a key and I put it in the car and security light is on. if i try cranking it it will act like it wants to run but goes shuts off. since it's going to be a race car is there anyway to by-pass the buck so it will run. what is your opinion? thanks
Jul 9, 2019 at 12:25 PM
  • 110,244 POSTS
Welcome to 2CarPros.
Honestly, I don't believe there is any way to bypass the security system. What model is it? If I have that I will check to see what is required for a relearn on the security system. However, it may require programming.
Jul 9, 2019 at 2:02 PM
