Spider not spraying fuel after replacing spider injector assembly
2006 CHEVROLET SILVERADO
190,000 MILES
CLAY NORMAND
Replaced spider injector assembly. It is not spraying fuel to start truck?
Sep 27, 2021 at 10:12 AM
Good morning,
Did you check the pressure on the spider from the fuel pump?
Fuel Pressure (Key "on", Engine "off") .................... 379-427 kPa (55-62 psi)
You can rent a tester to verify this pressure.
Check the electrical connector at the spider for any damaged or bent pins preventing the operation of the spider.
Let me know the results when you can so we can continue if it still does not run.
Sep 27, 2021 at 6:45 PM
CLAY NORMAND
Yes pressure is good.
Sep 28, 2021 at 12:28 PM
