spesifications / manuel
140,000 MILES
ZLOCHEVSKI
I am trying to find out how to get a repair manuel, for model FS, what is the diference between LX, EX and FS.
At this time I am located in Israel, and having dificulties to get one.
I NEED TO AJUST THE BRAKE BOOSTER ROD, AND DO THE VALVE LASH,( I BELEAVE THIS YEAR ITS NOT AYDROULIC),
BUT I CAN BE WRONG.
I inspected the, master, rotors and pads, all OK.
the symptom is, when I attemp to brake normal, I get a sadden brake, almost like blocking, but it's ABS.
Mitchell has only models EX and LX
VIN jmzw69s511212525.
Thanks
Apr 23, 2013 at 1:50 AM
  • 31,937 POSTS
I believe that the only difference is the level of trim appointments and the mechanicals will be the same, i would confirm this with a dealer, if you do not have one near you, do a on line search and send them an email with the information you require to confirm this for you.
Apr 24, 2013 at 8:34 AM
