Probably a problem in the speed sensor circuit. Have the codes read first to get a starting point.
Feb 14, 2016 at 2:36 AM
MEMNOC
MEMBER
Replaced one speed sensor and instrument cluster...no results
Feb 14, 2016 at 2:38 AM
WRENCHTECH
✓Experienced Mechanic
I advised you to read codes, not replace parts.
Feb 14, 2016 at 3:23 AM
MEMNOC
MEMBER
Will take your advise and get back to you in few days....parts are pretty speedy these days.
Feb 14, 2016 at 4:36 AM
WRENCHTECH
And costly
Feb 14, 2016 at 4:48 AM
MEMNOC
MEMBER
That's what I meant to say...speedy...not speedy...typo. Just curious though, does the instrument cluster have to be (synced) to the old one..
I know some cars do...even though neither worked. Still will take advice and have vehicle coded.
Feb 14, 2016 at 6:02 AM
No they should work no problem, can you check the drive gear to the sensor?
Mar 7, 2016 at 3:50 AM
WRENCHTECH
Here is what the drive gear looks like that Ken was referring to. Having the codes first though would tell us if we are even in the right area.
