My truck 1500 has an electrical problem I think. Starts and runs okay, but all the gauges bounce from completely off to part way up. The bounce together. The odometer flashes as well. The beeper beeps and the airbag light stays on until you buckle the seat-belt. The the airbag light goes out, and the beeping stops. The beeping used to only start after leaving park if the seat-belt wasn’t hooked.
Took to AutoZone and they said that it probably was the gauge cluster. But didn’t check for any codes.
Dec 19, 2018 at 2:32 AM
