speedometer sensor on transmission?
100,000 MILES • 0.5L • V8 • 4WD • AUTOMATIC
TYLER WILSON
The transmission went out on it I went to the junkyard got another one the transmission speedometer sensor is not on the transmission that I bought will it still start and run without the sensor?
Sep 22, 2025 at 12:41 AM
  • 55,772 POSTS
Sure it will start and run but it will not shift the transmission and you will have a check engine light on. Is there no place for the sensor? Every transmission should have one. Check out the images (below). Please upload pictures or videos in your response
Sep 22, 2025 at 10:07 AM
TYLER WILSON
Thanks you guys saved me a lot of work.
Sep 25, 2025 at 2:25 AM
  • 55,772 POSTS
You are welcome, please use 2CarPros anytime.
Sep 25, 2025 at 3:12 AM
