My speedometer reads 10-20MPH slow most of the time, then will sometimes slowly fall to 0, when it does and i left off the accelerator it is as if it goes into neutral until i slow almost to a stop, then it will take off again and shift normally as speedometer comes back to life but still reads slow and will not read faster than 58-59MPH regardless of how fast I'm actually going. If i try to set cruise control it will hold whatever speed I set it at until i read a point where the cruise control should retard to keep from going faster, than it is set for, but it will start accelerating and won’t stop until i tap the brake or turn it off.
With all this being said, at any time i can shift the 4wd selector control to auto FWD or FWD high and the speedometer will start reading perfectly and normally and cruise control will also work perfectly as well. Since this issue started i have had it to 4 different shops, I’ve had the transmission completely overhauled with new Zpak, all new electronics inside the trans, new ISS, etc. We have also replaced the speed sensor in the top back of the transfer case…nothing has changed the issue at all. Now I'm getting conflicting stories from different shops that the problem is a second speed sensor or 4wd control solenoid in the front top of transfer case, and another shop said there shouldn’t be…none of these shops have been able to fix my problem but all of them has gotten a chunk of money from me every time the work on it, including a $5,000 transmission overhaul. All of this has been done trying fix this issue. Now two of the shops tell me they have to remove the cross member and drop the engine and transfer case back down to replace a 4wd shift solenoid and/or forward transfer case speed sensor and they still can guarantee this will fix it!! Someone please help!
Also, I have also replaced the cluster with a used one and then had my old one overhauled. Please Help!
Sep 5, 2023 at 11:11 PM
