The car starts fine and runs fine until it gets to operating temperature. After that the speedometer will start to bounce really bad, then it feels like the engine starts to cut out for a few seconds then it will start working again then cut out again. If that happens and i put on the heat at max it will cool the temperature down and will stop bouncing and the engine stops cutting out also.
Replaced speed sensor and ignition coil already.
Mar 1, 2017 at 11:16 PM
