I would like to ask one more question, about the speedometer, does someone have an idea what can cause the problem?
The problem is: When you drive, the needle meter show the correct speed, but the digital meter show incorrect numbers. For example you drive 50kmh, and numbers say 40. When you stop, needle goes to 0, and digital numbers stuck to some value as 15 kmh or 20-25 kmh.
Oct 13, 2020 at 12:59 PM
