Speedometer problem
92,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
RPRASCHER
My speedometer drops ten to fifteen mph while driving at highway speed then returns. This also will shut off my cruise control if it is on. The cruise also will shut off without the speedometer dropping. I have had this to a mechanic and drove it with a reader connected. It showed an upward spike in the speed graph. We were thinking the speed sensor?
May 4, 2017 at 12:56 AM
HMAC300
  • 48,601 POSTS
then check to see if cluster is getting signal it may be a wiring issue or the dash needs to be rebuilt. If it is not getting a signal replace the speeds ensor here is the location of the sensor and a video of the job being done for the cluster replacement with a rebuilt unit.
https://youtu.be/_HEC44xENxw
May 4, 2017 at 5:26 AM
RPRASCHER
I have had a mechanic check all the wiring and sensors we swapped out the cluster tht fixed it, thank you so much for the video.
Jul 13, 2017 at 7:54 AM
HMAC300
  • 48,601 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Jul 13, 2017 at 8:03 AM
AZRAGE52
Electrical problem
2005 Chevy Avalanche V8 Two Wheel Drive Automatic 75k miles
i change my battery in my truck , as a result of this my truck, speedometer went out ,only work every now and then . also my truck sometimes doesnt start . I check the battery cables and they are both tightly installed. do you have any idea???
Jul 14, 2020 at 9:50 AM (Merged)
  • 110,248 POSTS
HAve you tried to reset the computer by disconnecting the battery for about 5 minutes then reconnecting it to see if that resets it?
AZRAGE52
yes i have tried that, with no luck
MDYKE
mt speedometer shows from 80 to 120 while sitting still. this after using the cruise control. what could cause this?
  • 110,248 POSTS
Have the vehicle speed sensor (VSS) checked. If it is good, then there is a good chance the cluster itself may be bad.
Let me know what you find.
GOODER
My speedometer is pegged at 120mph and won't move. I have already replaced the speed sensor but that was not the problem. Is there a part to be replaced? I can't seem to find anything on the internet.
RHALL77
  • 3,361 POSTS
most likely you will have to replace the IP cluster. You can go to your dealer and have a sweep test performed on it to see if it will start working. But i think you need a cluster
RHALL77
  • 3,361 POSTS
i would suggest buying one form a dealer, they have a warranty and will stand behind it if something goes wrong. i have had nothing but problems with parts purchased off the internet
CHEVYP2P
My speedometer is not working right the speedometer gauge is giving me a wrong reading. does any one knows how to fix if
Jul 14, 2020 at 9:52 AM (Merged)
87BANSHEE
  • 15 POSTS
You need to replace the instrument panel cluster. This is a common problem with these trucks. You will have to get it programmed at a dealership.
DIP
Electrical problem
2004 Chevy Avalanche V8 Two Wheel Drive Automatic
SPEEDOMETER NOT WORKING
RHALL77
  • 3,361 POSTS
is it stuck in a certain position. you may have a bad cluster causing it? the stepper motors are known to go bad in them
JAIME818
my speedometer is not working. i changed the speed sensor. still does not work!
KYTERRYLEE
  • 8 POSTS
You need to call a dealership and make sure there are no recalls or TSB's. If there is not, you can find used instrument clusters for not much $ and you shouldn't pay more than an hours labor to have it replaced. Hope this helps!
ANTHONY HALL
All my gauges are not working. The speed odometer, tach, fuel, temp etc won't register. Has a fuse that controls all these gauges blown or is this more serious? Thank you
SAILOR.JERRY
9 times out of 10 it is the cluster that has gone bad here is a video that can help you see how to fix the problem.
KYTERRYLEE
  • 8 POSTS
Check with your Chevrolet dealer on the cluster as well, it fixed my car. This site rocks
DAMIAN CHRISTIAN
  • 5 POSTS
I was driving and tried to use my cruise control then all of a sudden my speedometer went to zero and he wouldn't shift.
I can manually shift it from first to second but that's it. It allows me to rev high while I'm driving. I replaced the vehicle speed sensor and a wheel speed sensor with no luck. Also have an ABS and brake light on. No codes involving either on my cheap code reader.
Do you have any codes? As I was reading, I was suspect a vehicle speed sensor but you have an input and output speed sensor. Do you know which one you replaced? Was there a reason you replaced it or were you guessing at what it could be?
Let's start with checking for codes and which speed sensor you replaced and we can go from there. Thanks
DAMIAN CHRISTIAN
  • 5 POSTS
Not a mechanic or anything, so please bare with me. I only replaced 1 VSS and it was on then passenger side on the rear of my transmission. Only codes are p0101 and p0332.
DAMIAN CHRISTIAN
  • 5 POSTS
Also, it was a guess.
So you were correct that there were no codes that appear to relate to this issue. Included the MAF info for reference at this point.
Was the check engine light on when this was happening? Is the vehicle still acting up?
I also attached the location of the speed sensors. Was the location of the sensor you replace #2 or was it in the tail shaft?
It feels like we are missing something so we are going to have to work through this until we find the missing piece.
DAMIAN CHRISTIAN
  • 5 POSTS
So the only codes that were shown prior to this were the same ones I listed which included a code for an 02 sensor which I ended up figuring out (blown fuse).
All of the speedometer not working and not shifting happened at the same time. Still currently having the issue. According to your pictures, I replaced number 2.
I am sorry. I should have been more specific. Do you know which transmission you have? Either the 4L60E or 4L80E?
If the sensor was in the location shown in the first attachment then you have the 60. If it was in the second attachment #2 then you have the 80. This makes a difference because the speedometer and shifting are determined differently.
If you have the 60 then you only have the one sensor. The 80 has two so we need to make sure we know what we are working with or we are going to get really confused (more then currently).
The difference of the two sensor locations is the 60 is in the tail shaft and the 80 as the rear sensor just over the rear of the trans pan.
DAMIAN CHRISTIAN
  • 5 POSTS
Also 4l60e.
Okay. That is good news and bad news. Good news is, I think I know how we can find out what the issue is. Bad news is, we need to monitor the data from the PCM which means we need a scan tool that can do that.
Take a look at the wiring diagram. This is the vehicle speed sensor to the PCM, which shares the data with the throttle actuator control module.
The thing that tipped me towards this was that you tried to use the cruise control and this happened all of a sudden. The thing that I can't figure out is why you have no codes. This is why we need to monitor what the PCM is seeing.
Also, I doubt this is the issue because you have no codes but check the fuses in the second attachment. These are the fuses related to the cruise and I suppose they could cause an issue like this. Again, the no codes thing is throwing me off.
Let me know if you have good fuses and then if you have access to a scan tool so we can see what the speed sensor is telling the PCM.
