Speedometer pin idling (starting) at 100kph after jump starting
2004 PEUGEOT 206
186,411 MILES • 2WD • AUTOMATIC
JOSHUA GREEN
Recently my car battery died, i tried to jump start and all it did was move the speedometer pin forward every time i tried to start it. so i replaced the battery, the speedometer pin does not go back to 0, it just started idling/starting at just over 100 kph. The speedometer still works, it's just that the pin is not starting in the correct position.
What could be the problem here?
Cheers
Feb 27, 2019 at 3:36 PM
  • 55,399 POSTS
It sounds like the lack of voltage has stressed the gauge causing the new reading. It may come back in time but if not the cluster will need to be replaced. here is a video of the job being done on a similar car so you get the idea. The process is the same.
https://youtu.be/_HEC44xENxw
Mar 1, 2019 at 5:17 AM
