While driving down the highway, the speedometer started to bounce around from 60 - 0 and back again.
After a bit it stayed at 0 and has not moved again.
Noticed that the odometer and trip odometer also stopped turning and the check engine light popped on at the same time that all of these stopped working.
The car still runs the same, so figuring the Check Engine light is related to the above only.
How does one fix an issue like this? Old car, guessing this is a big job as it involves likely removing the dashboard?
Thanks!
Lisa
Thanks!
Lisa
Jun 9, 2014 at 12:00 AM
