Speedometer, odometer, and tachometer not working
109,000 MILES • 5.7L • V8 • 4WD • MANUAL
ANTHONY PRICE
just bought an 1989 k1500 and the speedometer, odometer and tachometer weren’t and hasn’t worked.
Aug 5, 2020 at 5:31 PM
Good morning,
The speedometer and odometer are controlled by the vehicle speed sensor on the transmission.
In the dash, there is a buffer that changes the signal from the sensor to something the dash can read. This was a common failure back in the day. I attached the location of the buffer for you.
The speed sensor for the transmission is on the output shaft of the transmission. I attached a picture and circled the area where the sensor is located.
Aug 5, 2020 at 9:55 PM
