Speedometer not working, Already Replaced VSS
123,000 MILES
CRAZYBEE723
Had diagnostics say bad VSS , replaced it, still not working. Check engine light still one, same codes. Had wiring harness checked, fine. All other gauges working. Could the VSS part I got be faulty? Could the connection behind the dash be loose or unconnected? What else should I check?
Oct 7, 2013 at 10:43 AM
HMAC300
  • 48,601 POSTS
if your speedo works then it's not the vss. it may be something else have apro check this out as it could be a bad dash
Oct 7, 2013 at 11:41 PM
CRAZYBEE723
Speedo not working. Check engine light still on after replacing VSS. How do I check if bad gauge cluster, where the speedo gauge is bad? All other gauges (RPM, fuel, temp) working, just no speedo or odometer working.
Oct 7, 2013 at 11:52 PM
HMAC300
  • 48,601 POSTS
if it gets a signal and still doesn't work then it's the dash. normally a pro scanner can read that or not
Oct 8, 2013 at 12:16 AM
CRAZYBEE723
Thank you for reply, appreciate your help. I will have it scanned with pro scanner.
Oct 8, 2013 at 12:26 AM
