Had diagnostics say bad VSS , replaced it, still not working. Check engine light still one, same codes. Had wiring harness checked, fine. All other gauges working. Could the VSS part I got be faulty? Could the connection behind the dash be loose or unconnected? What else should I check?
Oct 7, 2013 at 10:43 AM
