Speedometer and odometer quit working
175,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
MENKE
While driving smelled something burning saw no smoke. stopped truck could not see anything. when restarted speedometer and odometer not working.
Feb 18, 2019 at 1:48 AM
Good afternoon,
Does anything else not function?
Does the transmission work correctly?
The sensor has no voltage to it. It generates a voltage to the ECM.
Feb 18, 2019 at 2:28 AM
MENKE
Everything else was working fine.
Feb 18, 2019 at 2:30 AM
Okay, good chance the dash cluster itself has failed internally.
To confirm, I would have someone with a scan tool see if they can monitor the speed on there scan tool.
If they can, the cluster is bad.
If they cannot, it sounds like a wiring harness issue.
Feb 18, 2019 at 2:40 AM
MENKE
Thanks, I'll get it checked out.
Feb 18, 2019 at 2:41 AM
Sounds like a plan.
Feb 18, 2019 at 2:43 AM
