Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Interior
Instrument Cluster
Gauges
Odometer
Not Working
Speedometer and odometer quit working
1994 FORD F-150
175,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
MENKE
MEMBER
While driving smelled something burning saw no smoke. stopped truck could not see anything. when restarted speedometer and odometer not working.
Feb 18, 2019 at 1:48 AM
Experienced Mechanic
Good afternoon,
Does anything else not function?
Does the transmission work correctly?
The sensor has no voltage to it. It generates a voltage to the ECM.
Feb 18, 2019 at 2:28 AM
MENKE
MEMBER
Everything else was working fine.
Feb 18, 2019 at 2:30 AM
Okay, good chance the dash cluster itself has failed internally.
To confirm, I would have someone with a scan tool see if they can monitor the speed on there scan tool.
If they can, the cluster is bad.
If they cannot, it sounds like a wiring harness issue.
Feb 18, 2019 at 2:40 AM
MENKE
MEMBER
Thanks, I'll get it checked out.
Feb 18, 2019 at 2:41 AM
Sounds like a plan.
Feb 18, 2019 at 2:43 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
