erratic speedometer will not go above thirty mph
193,000 MILES • 2.4L • 4 CYL • AUTOMATIC
BILL STRU1
I replaced the output speed sensor, no change. I watched your video on replacing the ABS module,no change. I have replaced the instrument cluster,no change. I did a five hour reset each time. where else should I be looking? this one has me stumped. thank you for your help. Bill
May 31, 2017 at 11:40 AM
  • 55,732 POSTS
It sounds like you have some wiring issues or a bad connection. Here is some instrument cluster wiring diagrams (BELOW) and a guide so you can do some testing.
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
Jun 3, 2017 at 5:36 AM
BILL STRUBLE
ok i've gone through the wiring,what I can get to..I can't determine what wire is ground at the sensor...the schematic dosen't show ground...if it does it's not labeled.
Jun 25, 2017 at 2:48 AM
  • 55,732 POSTS
It is circuit 20 and the ground should be located near the pillar. Its in the second diagram.
Cheers, Ken
Jun 26, 2017 at 2:36 AM
BILL STRU1
ok everything is ohming out correctly voltage checks at sensor are good also..what can I check in the abs side of this...would a bad abs speed sensor cause this?also should i have an output voltage to the speedo?
Jul 2, 2017 at 3:24 AM
  • 55,732 POSTS
A bad wheel sensor can cause this for sure, here is a guide so you can test it. There is no speedometer output though.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Please run this test and get back to us we are interested to see what it is.
Cheers, Ken
Jul 2, 2017 at 12:05 PM
