speedometer and odometer not working
72,000 MILES • 1.8L • 2WD • AUTOMATIC
TOMTEM
my car's speedometer (0kph), odometer (stuck in 72k ) are not working and also ABS, PS, and E break lights are on. What could be the possible problem?
Apr 4, 2022 at 2:38 AM
  • 110,248 POSTS
If the vehicle has ABS, the speed signal is provided by the vehicle speed sensor. If a failure occurs, you will get exactly what you described. The speedometer will become inoperative, and PS, ABS, and parking brake light will illuminate.
Here is what I suggest: We need to determine if my theory is correct. To do this, the vehicle's can-bus system needs to be scanned. CAN stands for controller area network. Basically, all the different computers/modules are tied together via a few wires. A basic scan tool won't retrieve codes from the ABS module, so that is why I recommend this.
If by chance you have this type of scanner, here is a link explaining how it's done:
Let me know if you are able to have this done. If not, I can provide the directions for replacing the VSS, but want to be sure first.
Apr 4, 2022 at 12:49 PM
