speedometer just stop working what can be the problem? how can I fix it?
Jul 18, 2016 at 7:26 PM
HMAC300
✓Experienced Mechanic
scan for codes it may be the speed sensor auto parts does for free. also check wiring and connections for chafing and or poor connection.
Jul 18, 2016 at 10:31 PM
SCHALKNEL
MEMBER
where is the speed sensor located?
Jul 18, 2016 at 11:15 PM
HMAC300
if you replace it your check engine light will stay on as it needs to be erased by a scanner. the sensor is on the transmission, but there are two different transmissions in this car a ZF or ASIN check for a three way horizontal plug on transmission as we do not have a good picture location of it.
