My speedometer does not work. I change VSS
160,460 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
GUADA316
My speedometer does not work. I change VSS, but the needle for the speedometer still on 0. Everything else works fine.
May 20, 2018 at 12:04 AM
  • 110,248 POSTS
Hi and thanks for using 2CarPros.com There are two different speed sensors on this vehicle. There is an output speed sensor and a Turbine shaft speed sensor. The sensor which controls the speedometer is the output speed sensor. I attached a picture for you to confirm the correct one was replaced.
Let me know which one.
May 5, 2021 at 5:11 AM
