Intermittent speedometer not working properly
200,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JIM KLOHR
Sometimes my speedometer will respond when I start driving sometimes not. I found out that if I push the odometer zero button in it will either respond immediately or within the next few seconds or minutes this can also sometimes make the engine light go out if it was on.
Aug 26, 2020 at 12:37 AM
This sounds like a possible cluster issue. The vehicle speed sensor sends a signal to the cluster where it displays the speed. However, let's start with checking for codes the next time the check engine light comes on. You can try and check for codes now but I am not sure they will be there.
Let's start with this before we replace any parts because that could point us in a different direction.
Aug 26, 2020 at 2:25 AM
JIM KLOHR
That was not my question.
Aug 27, 2020 at 4:10 AM
Okay. I guess I misunderstood the idea that you can make the engine light go out by pressing on the cluster. I understood that to mean the light was on. If it is on then there should be codes.
As for the speedometer not working properly, that gets a direct signal from the vehicle speed sensor. Take a look at the wiring diagram. I highlighted the wire from the speed sensor to the speedometer.
If pressing on the cluster gets this to work, I can only imagine there is a circuit board issue with the cluster causing this issue.
If this does not address your question please provide more detail about what I am missing. Thanks
Aug 27, 2020 at 12:30 PM
