Speedometer does not work in the morning
88,000 MILES
YESI22LA
  • 6 POSTS
When I drive the car a check engine light comes on and D for the drive starts blinking. my friend power washed the engine that’s when it started acting up. after I drive it for a little bit everything goes back to normal working fine. Also, I’m not able to program the remotes. I had a locksmith try to program them and he couldn’t. He was able to program the keys but not the remote.
Jun 22, 2019 at 2:30 AM
  • 55,732 POSTS
Lets look at the vehicle speed sensor which is sounds like it has gone out. here is the location and instructions on how to change it out. Check out the diagrams below try to use a OEM sensor.
Remove the air cleaner assembly (see AIR CLEANER REMOVAL/INSTALLATION ) and the intake air duct.
Disconnect the CVT output shaft (driven pulley) speed sensor connector, then remove the CVT output shaft (driven pulley) speed sensor (A).
Install a new O-ring (B) on a new CVT output shaft (driven pulley) speed sensor, then install the CVT output shaft (driven pulley) speed sensor in the transmission housing.
Check the connector for rust, dirt, or oil, then connect the connector securely.
Install the air cleaner assembly (see AIR CLEANER REMOVAL/INSTALLATION ) and the intake air duct.
Jun 24, 2019 at 8:13 AM
YESI22LA
  • 6 POSTS
It turned to be a sensor that was loose. So now it’s working good.
Oct 5, 2019 at 4:23 AM
  • 55,732 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Oct 18, 2019 at 7:13 AM
YESI22LA
  • 6 POSTS
I have an 07 Honda Civic hybrid when I’m driving I can here a squeak. Can it be my struts that are wearing out?
Nov 22, 2019 at 8:49 AM
  • 55,732 POSTS
Please post your new question here, you must be logged in:
Cheers, Ken
Nov 23, 2019 at 2:59 AM
