Speedometer does not work. Is it electronic or cable. If electric, where is sensor sending unit? Thanks.
Mar 14, 2018 at 5:05 AM
STEVE W.
✓Experienced Mechanic
88 should be a cable unit. The cable screws into the side of the tail shaft housing. It clips to the rear of the speedometer with a spring clip. Push the bottom of the clip in towards the speedometer head while you pull the cable back.
