Milliage can be red at start up but goes out after warm up. What might the cause be?
Jun 9, 2017 at 3:35 AM
HMAC300
✓Experienced Mechanic
if the cluster was not programmed to your vehicle then it will not work because they are VIN number specific or if it is original cluster then it may be time for a rebuild. have a mechanic scan for codes.
Jun 9, 2017 at 4:34 AM
SLIPBOB72
MEMBER
This is the original cluster/have a code scanner which I used but no codes came up. Thanks for the advice.
Jun 9, 2017 at 6:09 AM
HMAC300
it may be just the cluster going bad.then have a mechanic check to see if it gets a signal. they can be rebuilt.
