Speedometer check
150,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MICHAELESTYONS
How to check speed sensor?
Jul 26, 2018 at 12:13 AM
Good morning.
You will need a scan tool that can read live data. You will need to see if the sensor is sending a signal to the PCM.
A code reader will not work. you need an advanced scan tool to read live data.
Do you have a scan tool?
Is the check engine light on?
Jul 26, 2018 at 12:25 AM
MICHAELESTYONS
Do not have a scan tool, no engine light.
Jul 26, 2018 at 12:46 AM
Okay, if your speedometer is not working and the check engine light is not on, then there is a signal to the PCM. That means your issue is in the dash cluster itself.
It would have to be removed and can be sent out to be repaired.
Jul 26, 2018 at 12:58 AM
MICHAELESTYONS
Thanks.
Jul 26, 2018 at 2:02 AM
You are welcome.
Jul 26, 2018 at 2:04 AM
