speedometer
150,000 MILES • V8 • 4WD • AUTOMATIC
PACHYAUTO63
  • 40 POSTS
Is there a p-sensor in the transmission? I replaced all speed sensors and neutral switch ,but when i drive the speedometer goes crazy up and down. what is going on?
Nov 17, 2017 at 12:45 AM
F4I_GUY
  • 3,302 POSTS
When you say you replaced all speed sensors, which sensors are you referring to? Did you replace the vehicle speed sensor located on the transmission output side or the wheel speed sensors located at each wheel?
Nov 17, 2017 at 5:34 AM
PACHYAUTO63
  • 40 POSTS
transmission output side.
Nov 17, 2017 at 5:55 AM
JIS001
  • 3,412 POSTS
Is this an automatic? Also is the truck 4 wheel drive? If automatic do you know which transmission you have on here? Is it the 4L60E or the 4L80E?
Nov 19, 2017 at 10:20 AM
BARBARA1963
  • 99 POSTS
4l80e
Nov 23, 2017 at 5:29 PM
  • 55,710 POSTS
The speedometer output signal is generated by the PCM but my guess is the speedometer is bad though is the connections are all good. Try to remove the cluster and remove the connector then plug the connector too in to see if it was a bad connection.
Here is a video how on to do it.
https://youtu.be/_HEC44xENxw
It also shows a rebuilt cluster getting installed.
Cheers, Ken
Nov 26, 2017 at 10:54 AM
