Speedometer stuck at maxed out position
175,000 MILES • 4 CYL • FWD • MANUAL
CLENZER72
  • 14 POSTS
Started to pull the cluster, anything I should look for the would cause this? Speedometer does not move at all when driving. did not bother to see if odometer moves. Could it possibly need to be re-clocked to the right spot, or another issue I should look for? Thanks in advance.
Aug 12, 2017 at 7:39 AM
CARADIODOC
  • 34,413 POSTS
You are going about this all wrong. Intermittent voltage spikes can cause a gauge to go too high when the ignition switch is off. These are not the extremely reliable spring-loaded mechanical speedometers we had for almost one hundred years. They use "stepper" motors now that are run by a computer circuit. The motor is pulsed with varying voltages and polarities to place it in the desired position. When a voltage spike makes it go past half way, when the ignition switch is turned on, it simply magnetically looks for the shortest way to "0", and that is clockwise. It gets caught behind the stop peg at "0" or at the highest reading on the scale.
The fix is to just drive the vehicle faster than half of the highest reading. Once the shortest way to the desired reading is counter-clockwise, the pointer will bounce there, then follow the speed back down like normal.
An alternative is to use a scanner in test mode and run the gauges through their paces. The final step is to run all of them back down to "0".
Aug 12, 2017 at 12:25 PM
CLENZER72
  • 14 POSTS
I reset the needle to zero, drove it slowly just to verify that the odometer worked (that eliminates the speed sensor correct?) so the next step would be to drive it above 60 miles an hour and see if that point because the needle did not move once I move it to zero
Aug 23, 2017 at 5:24 AM
  • 55,628 POSTS
It is sounds like the speedometer has gone out and needs to be replaced.
Aug 24, 2017 at 4:19 AM
CARADIODOC
  • 34,413 POSTS
If you physically pushed the pointer to "0", you're done. That's the hardest of the three ways to do it, but the results are the same, assuming you spun it counter-clockwise. Driving faster than half scale is the easiest way to do the same thing. You can also perform the gauge test procedure with a scanner. That runs every gauge to full scale, in steps, then back to "0".
Regardless how you got the pointer to "0", the job is done, and it will work normally unless the instrument cluster is defective.
Aug 24, 2017 at 2:03 PM
